Drag & Drop - Vault to Application
I would LOVE to see Drag'n'Drop functionality from Vault to Inventor Assemblies and the Application Window, While keeping folder references valid.
At the moment you can Drag'n'Drop files from Vault to Inventor, but it opens them from a temporary directory. Now that Vault allows us to specify a default Project File. it should be able to open the part from the working directory instead.
Ideally it would allow us to drop a file into an assembly by dropping into the assembly file edit window or open a file by dropping onto the application title bar.
This functionality would enable users to search Vault for parts using keyword search (skip the 3rd party PLM system in our case), browse the search results using thumbnails, then just place the desired part straight into our assembly without the need to 'Get' the files, then 'Place' them.
Awesome idea... Make sure you spell my name right in the credits!
33 Comments
RonnieHan
This is a feature back in 2011 available in Solidworks Vault.
In Vault 2022, Drag a part from external vault into inventor assembly will cause the part being in the temporary folder instead of the part belonging to the vault after drag and dropped into inventor. this feature works perfectly with Inventor and Vault 2021 but stopped working since upgraded to 2022.
I highly recommend this issue to be fixed as it is the feature of the best part of Vault. It is disabled now and reduces the work efficiency significantly.
Uwe_Lindner
Please use Vaulkt standard functionality ==> Insert CAD - It works fine
ScottDurham
Can someone confirm that the Insert in CAD function is available only in Vault Professional? The option appears to be missing in Vault Basic 2021.
Thanks!
SER4
@ScottDurham it does work in Vault Workgroup 2019.
Uwe_Lindner
Please check the path of the document in the properties.
This is not in the working directory, but the document is temporarily placed in the path c:\Temp.
In addition, the document has another name.
It is therefore outside the Vault Workgroup structure and, from our point of view, is corrupt.
Uwe_Lindner
@SER4 - the only possibility is use Vaulkt standard functionality ==> Insert CAD - It works fine
Philipp.Voegerl8BHJS
Community Visitor
An official feature would be very good to be able to drag and drop parts and assemblies from Vault into Inventor assemblies.
Tags (5)
M.MartinezELMO
Can't believe this issue is not solved yet in Vault Basic 2022, as said before by a colleague, this could be definitely a game changer...please Autodesk consider this issue.
ihayesjr
@M.MartinezELMO
Why doesn't the "Insert into CAD" option work for you?
M.MartinezELMO
We don't have this functionality, we are working on Vault Basic.
Should be in this menu, right?
ihayesjr
Sorry, this is a Workgroup and Professional only feature.
owlund
When creating new designs in Inventor, we often use parts from existing designs. Being able to drag & drop from Vault would be game changing. Currently we have to open the other design and copy while flipping back and forth between several assemblies.
Uwe_Lindner
If you use "Place from Vault" functionality, then can you a multiselect insert from parts and assemblys.
Yes, it's not drag and drop, but it's a way to effectively insert multiple components from Vault into an assembly at the same time.
2025-11-14 07_53_11-Autodesk Inventor Professional 2025.png2025-11-14 07_55_34-.png
