Show only
Search instead for
Do not show OBSOLETE items when using Place From Vault
I need to see files that have the Lifecycle State OBSOLETE in Vault Explorer, but I don't want to see them when I'm using Place From Vault command in Inventor. It would be very handy to have a toggle for this in the Place From Vault window.
This makes absoute sense. I will add one more. If you have files in the vault that have the state of "Released" and vault KNOWS you can't check it out, if you just want to open it up to look at, why on earth does it ask you to check it out when it won't let you because of the released state!!!!
Furthermore, I have Vault configured to not show OBSOLETE files for certain users, but when these users place files (not OBSOLETE) on an ECO and then change the file State to OBSOLETE, the files then can't be seen on the Records tab of the ECO. I think that in an ECO all files should be visible regardless of State or user permissions.
Hi, it seems like Autodesk tried to solve this with a filter but in my "place from vault" dialog box it does not hide obsolete files. Does anyone know how this function works?
