Show only
Search instead for
Delete Vault from ADMS. "No" should be default in this prompt: "Are you sure you want to delete vault xxx...?"
If you select to delete a Vault from ADMS Console, it will ask: "Are you sure you want to delete vault...?". The default answer in the dialog is "Yes". I think the default should be "No" since "Yes" has some quite drastic consequences.
