Dark Theme
Dark Theme
There is a real need to have a dark scheme on Vault.
With the white theme there is a huge amount of brightness causing eye strain as it is on a lot of the day.
We run Windows 7 so have very little scope to adjust the windows theme to do this and the high contrast scheme is not usable as some items are not compliant. It needs to be as a in built theme as per AutoCAD.
38 Comments
YounesYammouri
Status changed to: Accepted
YounesYammouri
patrick3HNXX
When can we expect a dark theme? My eyeballs are melting!
YounesYammouri
Vault Client Dark Theme is available in Vault 2022.2 Update as a Tech Preview.
Please join the feedback community to get details how to turn this on.
@senthilkumar please add details regarding Tech Preview Dark Theme & feedback community.
patrick3HNXX
Ok I joined the feedback community but I am not sure how to find that information.
PualQuek
@patrick3HNXX I have just sent an invitation email with the relevant instructions to your mailbox relating to the Dark Theme.
Regard,
Paul
gavin.allenHSSRX
Please can you Dark Theme the websites too (Autodesk one) TYVM
F_Doerr2202
@PualQuek @YounesYammouri can you send me an invitation too?
Jason.Rugg
@YounesYammouri I see in a comment above that you stated the dark theme would be available in the 2022.2 update. I just installed 2022.2 this morning, how do you switch over to the dark theme? Thanks
PualQuek
@Jason.Rugg I will send you a PM relating to how to switch on the Dark Theme (Tech Preview) in 2022.2 Update.
richard_grove
@PualQuek ,
Would you be so kind as to provide me with the details on how to switch to Dark Theme?  Thank you.
PualQuek
@richard_grove I will send you a PM on the details.
amin.nurdin
[cid:3402081c-0674-45a7-9c0a-a04120c5edc5]
Hi Richad,
you can set in "Tools" menu then choose "Options".
there is Theme you can select from dropdown.
it's still on beta. link for try
fridtjofZM5ME
@PualQuekHi, I would very much like to get the link needed to turn on dark mode in Vault Basic Client 2022.2.2.
Senthil_Kumar
Vault 2023 Release now supports Dark and Light themes along with Default Classic Theme. Themes are available only in Vault Pro 2023 and Vault Office 2023.
fridtjofZM5ME
@Senthil_Kumaris it now...?
Shouldn't there be a drop-down menu labled "theme" just about where I've drawn then red question-marks?
That this wasn't applied to Vault Basic 2023 as well as Vault Professional 2023 was about the largest dissappointment with this release. I sincerely hope this will be mended in the VB2023.1 update (or in VB2023.0.1 for that matter).
Senthil_Kumar
@fridtjofZM5ME
Sorry I should have mentioned. Themes are available only in Vault Pro 2023 and Vault Office 2023. Hope that clears your doubt.
fridtjofZM5ME
@Senthil_KumarAre there plans to implement it in Vault Basic as well? It's pretty much the last piece of software that doesn't have a dark theme, and this doesn't exactly strike me as your typical "DeLuxe"-feature either. The desire for the feature is there.
