I'd like to disable a specific Vault command in a menu in Inventor Professional 2026.
How to reach the menu: load a file in Inventor, go to Vault tab → Show Details → select a tab with a file list, such as "Uses" → right‑click file.
Here I want to disable the "Assign/Update Item" context‑menu command.
The reason is that the user doesn't accidentally run the Autodesk out-of-the-box command, and thus break the business process and/or the CAD structure metadata. We have our own custom Assign/Update Item commands.
Along with disabling UI access, disabling should also prevent any access to it via APIs.
