Check in/Check out should be an option, why don't we use lock's on documents?
Why don't we make Check in/Check out optional?
Example with document locks and without Check in/Check out:
I'm working on a fast network and data loading is not an issue.
Why do I need to Check out then?
I just want to (automatically) lock the documents I'm working on and I do not want the hassle of Check in/Check out.
So, when I hit the Save button everything is saved into Vault.
Example with Check in/Check out:
- When I'm going to work on site, I can just check out all documents I need and when I'm back I can check in all these documents.
- when I'm working at home trough a "slow" internet connection, I do not want all the traffic every time I save something, then I need to use check out at the beginning of my work and check in when I'm done.
This can be a user setting but also needs to be a admin setting to overrule users.
3 Comments
ihayesjr
Status changed to: Accepted
Senthil_Kumar
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly- it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Vault product team
Senthil_Kumar
Status changed to: Archived
