change dynamic size at folder window
User missing to change dynamic the folder window in Thin Client.
At Vault Client its possible to make the folderpart bigger or smaler.
At Thin client the window have only the slider at buttomside. It's not ease of Use for Users.
13 Comments
randracki
Yes this type of adjustment is needed during a typical Thin Client session
CraigHarshman
Does Autodesk have plans in the works to allow for this to be adjusted?  It is very limiting with that pane not being able to be adjusted.
johnson_baumans
Community Visitor
As a neutral person this should also work neutrally, for visually impaired people this is not the way to work!
francis.korde
on wide screens, it gives an impression of confinement. and browsing with this browser is often faster. This evolution would be very practical.
ssdimpfl
This change is definitely needed.  I was told today that there is a very hard to see scroll bar at the bottom of the window that at least allows you to scroll the folder tree over to see what's being cut off.  But that's a whole new enhancement request needed:  Dark Mode is great however there needs to be a little more contrast to the scroll bars so that people can see if they exist / how far down in a list they are viewing.
ihayesjr
Status changed to: Accepted
ihayesjr
Implemented in Vault 2025.1 Update
Uwe_Lindner
Sehr gut - funktioniert!
Uwe_Lindner
Is there a plan to make this functionality available in the 2024 version?
ihayesjr
@Uwe_Lindner
No, this will be for 2025.1 and newer.
t_helle
Observer
Thanks to add it in 2024 version ! It's my request + 57 users ...
Best regards,
Thierry
marcel.boeck
this function is missing in my environment. I just installed the update 2025.2.1 for Vault Server and Vault Client. I tried different browsers. Can it be helpful to install the WebClient again?
Best regards,
Marcel
Uwe_Lindner
@marcel.boeck, in our environment with chrome browser it works fine. Users are satisfied! Please contact your Autodesk Partner for support.
