Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
Bring back Legacy Copy Design 2025
The new Copy Design they introduced in 2016 is awful and my company has never made the switch. When we updated to 2025 the legacy Copy Design was not able to be implemented. We don't need advanced features simply need to copy one design and reuse it again and again. We make the same product with just a few dimension changes. The new copy design is cumbersome and does nothing for productivity on the front end or once its complete. See image below for the naming and folder structure sequence. We do not need it to ay "Copy of" a hundred times or rebuild the entire folder structure from where I copied from.
2 Comments
ihayesjr
Status changed to: Archived
Thank you for posting the idea.
However, we will not be bringing back the old Copy Design. Please let us know if there are other changes we can make to the new one to help.
upchurt
@stephen.v you can use a similar interface using the Inventor Design Copy:
Copying an Inventor assembly using iLogic Design Copy
-Trent
