Autodesk Vault 'Clone Structure' Add-in - Make as permanent feature
Description
Starting a folder structure for a new project in Vault can be a timely process. From reproducing the folder structure, and in particular having to manually assign permissions to the newly created project structure.
Impact
Not having this feature has a significant impact on the process for starting a new project, particularly one which has a somewhat complex folder structure.
Due to this product limitation, it might actually put users/clients off from using Vault in the first place if there is such a time consuming project startup administration process.
Severity
Medium-High
Solution
Roll the Autodesk Vault 'Clone Structure' Add-in from Autodesk Consulting in as a permanent feature in Vault to aid in speeding up the project startup process.
http://underthehood-autodesk.typepad.com/blog/2011/09/meet-the-new-project-same-as-the-old-project.h...
6 Comments
ihayesjr
Rob.O
We use a standard set of folders for every project we do.  It would be really slick if Vault had an option to store a series of folders (including a few files) as a default standard and would allow you to create a new project folder from that set of standard folders (including all of the sub folders and files).
I do this now by keeping the standard folder structure in a CAD Management folder on the server and drag it into Vault when a new project is started.  Then a rename on the root folder and done.
Would be a nice feature if it was built into the software! 🙂
ihayesjr
Status changed to: Accepted
ryan
YounesYammouri
ihayesjr
Implemented in Vault 2024.
