Allow selecting revision for AutoCAD dwg Pack and Go
Pack and Go for a specific revision is available for Inventor files. Please make it also available for AutoCAD files.
4 Comments
ihayesjr
@arjenblok
Hi, I moved your post to the discussion for so we can talk about it. Pack n Go should already work the same for all files.  On the DWG file, in the History tab, select the specific Revision you want to pack, then select Pack n Go from the File menu.
arjenblok
@ihayesjr I understand the possibility you mention to select a specific revision for Pack and Go. Two questions about your option:
  1. Selecting from the history tab makes it cumbersome for multiple dwg files.
  2. My (or actually my customers) intension is to send the latest released version of selected files up to 100 at a time. The static revision setting in Pack and Go shows Latest. This implies that it packages also file versions which might not released e.g. edits on an as built (released) file for the next revision.
Tags (1)
ihayesjr
@arjenblok,
Ok, now I understand what you are asking for.  You are correct, this isn't currently available and would be useful.  I will move this back to the ideas forum.
Thanks for you input.
ihayesjr
