Allow Purge by Folder
Ref: Purge enhancements - Autodesk Community
Still need to ability to purge by way of folders.
On numerous occasions you'll have a need to purge a bunch of files, yet not others.
This is my current case where I have a ton of completed projects for which I need to purge all un-needed versions, but at the same time I don't want to touch the current projects.
Having the ability to purge by way of folders, I'd be able to conduct this process in one swing.
As it is now, I have to open each and every project folder, select the files, purge, repeat.
Instead of purging by folder and letting it run through everything as I work on other matters, I now have to spend hours doing the above process.
This is silly, help us out.
3 Comments
ihayesjr
@Anonymous
Thanks for posting the idea. Have you tried what is currently in beta in the feedback community?
ihayesjr
Status changed to: Accepted
ihayesjr
Implemented in Vault 2025.
