Add "GROUP BY BOX" to Preview Pane
When I'm enacting lifecycle management on a drawing (i.e. change from WIP to CHECK etc) and I select the drawing I can see the tree in the USES tab of the Preview Pane. I want to be able to use the GROUP BY BOX. This is helpful so I can select files by STATE or CATGEGORY and enact a lifecycle state change en masse.
Currently I can shift select the files and choose "change state" but if the files are not ALL of the same lifecycle I can't apply a new state with a single pull down. I instead have to select every file individually and apply the new state one-by-one. This is very time consuming for a drawing that is of a top level assembly with hundreds of files in it.
4 Comments
ihayesjr
Status changed to: Under Review
I think I should clarify.
I know that I can slect all the sub files and try to enact a lifcycle state change by grabbing the pull down and choosing the appropriate lifecycle. The root issue is if the files selected are not all in the same lifecycle state at that moment, (i.e. some are incheck, some are released, some are under review) AND I try to move the state by lifycyle one of two problems can coccur. 1) If I have permission to transition lifecycle state for the all the current states can can unintentionally move a file from Released to In-Check be cause it is part of my selection group from the USES tab view (i.e. I shift selecte an entire range of files). 2) If I don't have permissions to transition even just on of the states (i.e. I am not allowed to transition from under review to In check) then I can't move ANY of the files' lifecycle state to in-check because I don't have transition permission for a single file in the selection group.
So, if I can show my users to group by state and then only select In-Work (or whatever) when they want to transition lifecycles that is more comprehensible than trying to pick through the hang ups I explain above.
I hope this helps to clarify. I realize what I state here may seem a bit "out there" but I assure you it has a real impact on my company. I have 65+ users trying to transtion states a'' with varying levels of Vault comprehension. When they hit a snag like I describe here they through their hands up in frustration. Unfortunately this happens on a daily basis for us.
Senthil_Kumar
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly- it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Vault product team
Senthil_Kumar
Status changed to: Archived
