So, this is potentially a stupid question - but when looking for solutions, I quite often see references to "select in the item master".
Is the item master something different from the normal thing I'm looking at when I first open vault explorer?
The specific reason I'm asking is that I'm trying to attach/link a pdf file (spec sheet) to a model file. In the help, it says "right click on the item and select attachments" There is no "attachments" in the right click menu when I click on an "item", in this case an .ipt file.
I am able to attach the pdf to the .ipt using the actions menu, and look at the attachment list using the actions menu, or ctrl + click, but I'm not sure this is what I'm looking for.
I'm looking for some kind of link between the .ipt file and the pdf spec sheet, so I can get to the spec sheet from the ipt, or ideally, when I print the final drawing, also print all the associated pdf spec sheets for the purchased parts included.
