A better Vault backup script to remove old backups
ThomasRambach
Advisor Advisor
ThomasRambach
I just wanted to share the Vault backup script I've been using to backup the Vault daily. The script allows you to set the number of backups to save and it will delete the oldest beyond the number of backups you want saved.
{BackupFolder} : Set to your Vault backup location (3 locations in the script)
{Username} : Set to the Vault username
{Password} : Set to the Vault users password
skip=2 : This is set to save 3 backups. The 2 in the folder and the backup that will run with the script. Set this to at least 1.
@ECHO OFF
REM ---- Vault Daily Backup ----
    setlocal enableextensions disabledelayedexpansion
    pushd "{BackupFolder}" && (
        for /f "skip=2 delims=" %%a in (
            'dir /b /ad /tc /o-d'
        ) do rmdir /s /q "%%~fa"
        popd
REM -- Backup Vault ---
"C:\Program Files\Autodesk\ADMS Professional 2019\ADMS Console\Connectivity.ADMSConsole.exe" -Obackup -B"{BackUpFolder}" -VU"{Username}" -VP"{Password}" -DBSC -S -L"{BackUpFolder}\Vault_Backup_Log.txt"
RolfEven
Thank you for sharing this.
Best regards,
/Rolf Even
