how do I get rid of the yellow in this scenario,it not letting me save or check out the file
Solved by gandhey. Go to Solution.
You can checkout the parent file of this file and then checkin the same.
Later you should be able to checkout the concerned file.
regards,
Yogeshwar
(vault team)
There is no parent file, it is in the beginning stages this is the file.
Can you try deleting the file from your Vault workspace (hoping this doesnt have any local changes that you need - otherwise can make a copy locally to some other folder) and do checkout from Vault ?
Yogeshwar
(Vault team)
