Vault thin client 2026.2 Your session had expired, after 1 minute
JanInventor
JanInventor
After 1 or 2 minutes with no activity the Vault browser session expires with
"Your session has expired. You will be re-directed to the login page."
This should happen after 30 minutes.
Config file setting is 0:30:0 (default) and the IIS is 1740 (default)
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Your-session-has-e...
I did reset IIS
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-restart-Vau...
But still it expires on mulitple computers.
arkad_s
Autodesk Support
Autodesk Support
It might be the same as discussed here. Solved: Vault Thin Client Timeout - Autodesk Community
I hope solution mentioned there helps.
Arek
Arkadiusz Sukta
Sr. Technical Support Specialist
Customer Technical Success
JanInventor
Changing web.config <add key="SessionInactivityCheckInterval" value="0:5:0" /> into <add key="SessionInactivityCheckInterval" value="1:30:0" />
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Automatically-logo.....
