Vault Server size and Local Workspace size query
BL4849
BL4849
Vault 2012, Inventor 2012
(Standard Content Centre parts on local pcs)
My LocalWorkspace is 3.51GB in size but our Vault Server Filestore is 9.5GB.
I have done a "get" command on all items in the vault.
I have checked with another engineer and his local workspace is the 3.51GB also.
Can someone clarify this?
JorgenBjornes
Get gets latest version of all files. So two thirds of the files in the server filestore is probably old versions.
If you are using vault Pro/collaboration/workgroup it could also be that some folders are restricted for your user.
minkd
When you to a get on everything in the vault you will download 1 version of every file.  The vault filestore likely has multiple versions for many of your files.
-Dave
Dave Mink
Fusion Lifecycle
Autodesk, Inc.
