Using Vault 2013 pro.
I'm seeing that for most files, The properties 'Revision (Vault)' and 'Revision (Model)' must match to be compliant.
However, I've seen exceptions. I believe these were AutoCAD files, not Inventor Files.
What I can't answer is this:
How do I tell the Vault that the 'Revision (Vault)' property should or shouldn't match something else? Where does the compliance rule live?
The answer to that will tell me where to start looking to plug the hole in our drawing security.
Thank you.
Solved by awatt. Go to Solution.
Thank you.
Hello and welcome.
Not sure where you are seeing these two properties, can you elaborate? Are these both properties in your Vault setup? Are are you talking about the out of the box Vault system property "Revision", and a corresponding property on the file side? What type of files? Acad, Inventor... something else? How do you wish to control revisions, based on lifecycle? And last but not least (for now) are you using Items?
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
The compliance for the Revision would be based upon the settings for the property. So, if Revision is being written back to the Inventor iProperty but they are currently different, then you would have non-compliancy. If you bring up the properties grid, move over the red warning sign on the Reivison property and it will show you in the pop-up why the it is non-compliant.
-Ryan
