Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Vault Replace...
2 REPLIES 2
Cadkunde.nl
153 Views, 2 Replies
Vault Replace...
Hello Forum,
I Have a new content center family and wish to replace all old files with the new ones.
I made a script to create all instances of the new family and checked them in.
Then I go to the old family folder in Vault and select: Edit --> Replace...
Already replaced several instances of the old family with the new family.
Till I get to this file, I already did Replace... But there are still some links left visible in "Where used"
But when I go to the Replace wizard I see nothing:
Already tried Action --> update file reference, from both sides: The part, and the assembly where it is used.
Anyone got an idea what the problem might be and possible solution?
Additionally, I also get this annoying pop up whenever i switch from folder.
I have to click it away several times per replacement action
2 REPLIES 2
bonnrhee
in reply to: Cadkunde.nl
Have you checked out, opened the assemblies in Inventor, then checked them back in?
Cadkunde.nl
Yes, when checking in and out the content center file, it does not help.
Checking in and out the assemblies with vault does not help.
Checking in and out all the other files individually in Inventor is not preferred.
It's weird that they show up in where used, but not with replace
Technology Administrators
