Vault Professional Tree Structure Export?
phlyx
Advisor Advisor
Message 1 of 16
phlyx
Seems like this should be a fairly simple task but seems to be eluding me.  I would like to export the folder tree structure of Vault Professional 2024 to an Excel file.  I have been playing with Autodesk Report Template Utility but can't find a way to configure that to just export folders as that seems to create reports that are file based and not folder based.  Is there a report template available or some method someone has to generate a tree structure to an Excel spreadsheet?  Doesn't seem like it should be a complicated task.
Thanks in advance for your assistance!
Replies (15)
Message 2 of 16
andrewiv
I'm not aware of a way to do this, but it would probably be better to ask this on the Vault forum.  The Autodesk guys that work on Vault watch that forum and they would be able to give you an answer.
Andrew In’t Veld
Designer / CAD Administrator
Message 3 of 16
phlyx
Thanks, I'll post it over there.  I didn't click on SHOW MORE from the Product Design & Manufacturing forum index page so the Vault forum didn't show up.  🙄
Message 4 of 16
phlyx
Message 5 of 16
phlyx
Thanks for merging/moving this to the Vault Forums, now I just need a solution 😁
Message 6 of 16
phlyx
So, no engineer or Vault manager has ever had a need to output their Vault tree structure?  Wow......
Message 7 of 16
phlyx
When all else fails, keep digging for a work-around.
Is there any way to copy the complete Vault folder structure to your local workspace withOUT downloading any files???
Message 8 of 16
jose_oltra
Well, in fact, there's a workaround.
Connect to your database using ssms.
run the query:
SELECT [VaultPath]
FROM [<YourDB>].[dbo].[Folder]
Get that list on a TXT.
Replace $ for your WorkSpace folder.
Run a Powershell script to create all those folders.
Hope it helps
Inventor
Revit
Vault Professional
Autocad
Message 9 of 16
andrewiv
Out of curiosity, what do you need the folder structure for?
Andrew In’t Veld
Message 10 of 16
ihayesjr
The Get Folder command is available in Vault 2025 & 2026.
Vault Help | Get Folder from Vault | Autodesk
Irvin Hayes Jr
Principal Product Manager
Vault - Under the Hood Blog
Message 11 of 16
phlyx
Thanks!  I do not have admin right on my ws so might not be able to do that.
Message 12 of 16
phlyx
The company I work for started in the 1940's, obviously everything on drawing boards.  Then scanned on microfiche, then Unisys CAD, then AutoCAD, then Solidworks and Inventor (and then just Inventor), then we were run by a German corporation and they were pushing us to ProE (glad that never grew much), then we have changed hands a couple more times, merged several other companies with us, had several different product lines, each with their own engineering file structure, then random generated part numbers, then back to semi-intelligent part numbers divided by product line, then one number system for everything, and all of this is crammed into Vault.  We have probably +10,000 machines in the field that need to be supported, parts department goes crazy at times searching.  So I am trying to get a tree structure to make an index so we can find stuff quicker.... or sometimes even find stuff at all.
Message 13 of 16
phlyx
O..... M...... G..... MM=mm and IN=in and now we can get folder in Vault....???   I need to push for us to upgrade!!! 😎 Thanks!
Message 14 of 16
phlyx
WAIT!  2024 has get folder!!!   I can just get the empty folders to my local workspace and generate a tree structure from that!   DUH!!!!!!!!!!!!!!!!!!!!!!!!  LOL
Message 15 of 16
arkad_s
Autodesk Support
Autodesk Support
I know it is late input but I thought it might be useful for others looking here in futur. It is about original question - export tree structure to Excel. You can try performing advanced search on folders only, for example using "Name contains *"
Then you need to check if "Folder Path" is enabled and try to export results to Excel:
Just few remarks:
- Above example is for full list of folders where logged in user has "Read" permissions (folders restricted for logged in user won't be listed)
- Above example is for root folder (you might try playing around with selecting specific sub structure fi needed
Be aware about "include subfolders" option being enabled or disabled when reviewing results
- When list of folders is long (exceed paging) you might need to expand search fully before exporting
I hope that helps.
Arkadiusz Sukta
Sr. Technical Support Specialist
Customer Technical Success
Message 16 of 16
phlyx
@arkad_s thanks for the suggestion.  I actually did a "get folders" to my local workspace which created the entire Vault folder structure locally without files.  Then I just went to a command prompt (cmd), switched to my workspace and did a tree /a >vault-tree.txt and that gave me a complete tree structure in a txt document I can mark up.  I am a DOS-a-holic so still find some things DOS can do that Windows can't.  😁
