Vault Pro Project Sync and Bim 360 TEAM
ShayaGhanbar
Message 1 of 9
ShayaGhanbar
I know that Vault Project Sync was capable of syncing files with BIM 360 TEAM. Now that the BIM 360 TEAM does not exist anymore, does Vault Project Sync work with BIM 360 DOCS?
Thanks for you help!
Shaya Ghanbar, P.Eng.
Technical Specialist - MFG
SolidCAD - A Cansel Company
Replies (8)
Message 2 of 9
ihayesjr
Not at this time. We are planning this for a future release.
Irvin Hayes Jr
Principal Product Manager
Autodesk, Inc.
Vault - Under the Hood Blog
Message 3 of 9
ShayaGhanbar
Thank you @ihayesjr Irvin for the prompt response.
Is this going to be available in Vault 2020 or one of the future updates of the 2020 version?
Is there a timeline for it?
Message 4 of 9
ihayesjr
@ShayaGhanbar We can not provide a time frame when any feature is going to be released.
Irvin Hayes Jr
Autodesk, Inc.
Message 5 of 9
radu1234
Hi all
Now we know that Vault 2020 connects to BIM 360 Docs and relations are not supported. Is there any documentation about it?
Thank you
radu
Message 6 of 9
ihayesjr
@radu1234 ,
From the Vault Side, Project Sync will work the same way regardless if it is connect to Fusion or BIM 360.
BIM 360 documentation will have it's capabilities.
Irvin Hayes Jr
Autodesk, Inc.
Message 7 of 9
YounesYammouri
the limitation regarding Project Sync and BIM 360 supports are documented here:
https://knowledge.autodesk.com/support/vault-products/learn-explore/caas/CloudHelp/cloudhelp/2020/EN...
Important: BIM 360 use cases currently focus on data contained in a single file such as DWG and PDF. The following types of file references and relationships are not currently supported when using BIM 360 with Project Sync:
  • AutoCAD and Civil3D xrefs
  • Inventor references/relationship
  • Revit references/relationship
  • Microstation references/relationship
However we are working on removing some of those limitation in the near future.
Younes Yammouri
Product Manager
Message 8 of 9
ShayaGhanbar
@YounesYammouri Thanks for the info!
Message 9 of 9
YounesYammouri
short update on Project Sync for BIM 360 support for AutoCAD references. Since the last released Desktop Connector  Project Sync for BIM 360 include support for AutoCAD references:
http://help.autodesk.com/view/VAULT/2020/ENU/?guid=GUID-06E6DB88-C7F0-4173-A372-5467CC090327 (removed the previous limitation).
Desktop Connector for BIM 360 help (What's new in May 2019): http://help.autodesk.com/view/BIM360D/ENU/?guid=GUID-B0DEC673-9B50-40E5-9D68-3E10EDCCDE50
Best regards
Younes
Younes Yammouri
Product Manager
