Vault Pro folder permissions
G60Dub
G60Dub
Hi all
I'm our Vault Pro admin/Inventor build and tweaks guy and have discovered some new behaviour outside our permitted/accepted workflow.
This has likely crept in as we have multiple sites and I do not have visiblity of engineering staff based at other remote sites.
Engineers are permitted to create specific folders and filenaming under the projects folder and also the Standards folder however they should not create folders at higher path levels within the workspace.
Admins (me) manage the Design Data styles, templates and authored content center but otherwise anyone who is not admin should not be doing this.
I've never had an instance of this occure here or any place prior and as I currently don't have my dev vault running to test  - Is is possible to set read permissions on the 'Designs' folder and also modify on 'Projects' and 'Standards' such that standard engineering users cannot create subolders in Designs but have full modify rights otherwise?
folder structure for reference:
Inventor Professional 2025.3.2
Vault Professional 2025.3
ihayesjr
@G60Dub
Yes, it is possible just as you described.
The best approach is to test it in a test Vault.
Once you are comfortable with how it works, apply the change to your production Vault.
Irvin Hayes Jr
Principal Product Manager
Autodesk, Inc.
Vault - Under the Hood Blog
ihayesjr
For more understanding, review my AU class.
Security Awakens: Defending Against the First Order | Autodesk University
Irvin Hayes Jr
Autodesk, Inc.
G60Dub
Hi Irvin.
That's ideal -I'll also check out your AU class as well.
Many thanks again.
lauri_barnhart
Hello, @G60Dub,
Just checking in—did the responses shared by @ihayesjr help clarify your question?
If so, please consider clicking the "Accept Solution" button on the post(s) that solved your problem. Doing so helps others in the community easily find useful answers.
If your question still needs more attention, feel free to reply here with an update. This way, other members can jump in with further suggestions or guidance to help you move forward.
All the best,
Lauri | Community Manager
