Vault Pro 2020 Deployment
Raf_
Raf_
Hi
Is there any way you can deploy Vault Client using 'Sign In' (Like Inventor or AutoCad) option rather than serial number or network licence?
Replies (11)
ihayesjr
You are creating a deployment image for Vault Office which does not support the Sign-in option.
Irvin Hayes Jr
Sr. Product Manager
Autodesk, Inc.
Vault - Under the Hood Blog
Raf_
That was screenshot from Vault office deployment but i was using Vault professional installation files (Both are combined now Pro and office)
There is no 'sign in' option for Vault pro client deployment as well
gandhey
Please note the 'Autodesk ID' 'License Access' option is not supported overall for Vault 2020 in deployment creation - i.e. for Vault Professional as well.
regards,
Yogeshwar
(Vault team)
Raf_
Thank you for the replay, so how I supposed to deploy Vault ? Which option i should use? I dont have network licence or serial number only 'sign in' option licence is available in my account.
Regards
I beg to disagree there Yogeshwar.
When creating a deployment for Vault Professional 2020 there's no option to create a Sign In license access, just Serial Number (Stand-Alone) or Network. If you choose Serial Number and only have Sign In licenses you need to reset the license after installation of the licenses. The situation is the same if you choose Network and only have Sign In. To reset the license open a command prompt and navigate to:
C:\Program Files (x86)\Common Files\Autodesk Shared\AdskLicensing\Current\helper
Type the command below to reset the license:
AdskLicensingInstHelper.exe change --prod_key 569L1 --prod_ver 2020.0.0.F --lic_method "" --lic_server_type "" --lic_servers ""
Then you get the chance to select Sign In at first start. I assume the same goes for Vault Workgroup 2020. Change the product key 569L1 to 559L1 then.
You can also copy the text below into a cmd-file and execute it by double click on it:
cd \Program Files (x86)\Common Files\Autodesk Shared\AdskLicensing\Current\helper
pause
gandhey
Hi @Anonymous ,
I meant the Vault donot support that 'License Access' in the deployment creation.
Yogeshwar
(Vault team)
Yes, I see you edited your post now 🙂
But why is it not possible to choose sign-in when creating a deployment?
KevinHu_PDMS_Vault
As far as I know, Vault doesn't sell with user license type. could you please first check if your AutodeskID has the entitlement of Vault Profession or Workgroup from https://manage.autodesk.com? if you can see them, please try to expand its page and check if you find the Serial / Key. if yes, standalone license could work for you when creating deployment.
if you cannot find the Serial / Key and still want to use your account to create deployment. please follow below steps.
  1. Open install source package, backup copy setup.ini to setup.ini.sav
  2. Open setup.ini
  3. Find [GLOBAL_MSI_PROPERTIES]
  4. Add
[PRIMARY_MSI_PROPERTIES]
ACADLOCKTYPE=2
ACADSTANDALONENETWORKTYPE=0
ADSK_GLOBAL_PROP_LIST=INSTALLDIR;ADSK_LAUNCH_MODE;ACADSERIALNUMBER;ACADSERIALPREFIX;ACADLOCALEID;ADSK_EULA;ADSK_EULA_STATUS;ADLM_EULA_COUNTRY;ACADSTANDALONENETWORKTYPE;ADLM_PRODKEY;ADSK_PRODUCTKEY_VALIDATED;ACAD_LICENSESERVER_DISTRIBUTED;ACADLICENSETYPE;ACADLICENSESERVERTYPE;ACADSERVERPATH;ACADSERVERFMTPATH
5. Save setup.ini
6. Create deployment with your AutodeskID
jzarczynski
It allows to create a deployment of Vault Proffesional with Log-on activation option.
I was unable to create the deploment of Vault Office (on the next screen Vault Proffesiional is aleady chosen and i cannot change it to Vault office). How to solve this problem ?
I just bought Autodesk Log-in licenses for Vault office.
GunnarNilsson
For Vault Office you should select product key 555M1 instead of 569M1 for Pro
pcoleman
Hi Kevin
We are trying this method with Vault 2018 Office. But it seems to be making the Vault Office selection unavailable. Any ideas to make office available for selection as a sign in user?
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
