Hello, I do not accept this as a solution.
When a file with multiple model states that do not yet have unique part numbers is assigned an item, the item is assigned to the file only. If the model states are then assigned unique part numbers and the file is saved and checked in, assign/update item DOES NOT create new items for the model states with new part numbers.
Deleting the item and re-creating it is the only way I have found to get items assigned to all model states. This is fine unless the item history or other links must be maintained.
Saving the file as a new one and creating an item from that will "work" but in that case the original file AND original item will need to be deleted, assuming one has a clean vault, and item history retention is not required. I believe I also read that creating new duplicate model states and assigning part numbers to them will work, after which you would want to delete your original model states.
I understand that model states are relatively new, and I think they are a wonderful addition to the capabilities of Inventor. I use them frequently. However I think the inability for assign/update item to recognize existing model states with newly assigned part numbers is an oversight on the part of Vault Pro that should be addressed.
Am I missing something? Is there a property mapping conflict causing this? I have "Part Number" mapped both ways between file and vault properties.
