Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Vault - Copy Design Small Column Width
3 REPLIES 3
317 Views, 3 Replies
I sometimes have a problem when I do a copy design. The column width is very small and the information is not clear:
The column width is fine after I clicked Folder View, List View or when I double click the column width, however it's annoying to do this every time.
Is there any way to fix the column width? This problem not only occurs with me, but also with my colleageus.
3 REPLIES 3
ShayaGhanbar
This is a common problem and I have seen it many times. By the look of it, you are using Vault Basic. The Copy Design function is changed (improved!!) for Vault Professional since Vault Pro 2016. I don't think that Autodesk will invest in the free version of Vault (Vault Basic) anytime soon.
Did you find this reply helpful?  If so, please use the Accept as Solution or Kudos button below.
Shaya Ghanbar, P.Eng.
Technical Specialist - MFG
SolidCAD - A Cansel Company
in reply to: ShayaGhanbar
It's a small consolation that we are not the only one facing this problem. Still I'm surprised that AutoDesk doesn't try to solve it (even if it is a free version). What is the best way of notifying AutoDesk of this problem, maybe if enough people complain about it they're going to try to solve it
ShayaGhanbar
I totally understand your frustration. Here is where you can create a request: https://forums.autodesk.com/t5/vault-ideas/idb-p/2/tab/most-recent
People look at your request and they vote for it. You find out that some one has already create a request similar to your so you just have to vote for them.
