Upon pressing the Update... view (DWF file), we receive the msg below, what might this message mean?
Update View Restrictions
Visualization file cannot be created due to vaulting restrictions
Restriction: Non unique visualization file
What is a non unique vis file?
Has this issue been reviewed, as I am having this very same issue mentioned above two years later (using 2012).
Is there a better way to deal with this issue that I'm not aware of? The two "Workarounds" mentioned above are not acceptable, as the number of times this would need to be done in one day would be overwhelming. It seems to me, if you're deleting a file from the Vault the .dwf should automatically be deleted as well. The .dwf files are typically hidden, so what would I need to keep a hidden .dwf file in the system for? Turning off the unique file names is unacceptable because we would like to keep our Vault free of duplicates. How should I proceed?
Len
