Check to see if you can ping the server from the PC. You might also need to put in the FQDN (Fully Qualified Domain Name)...so if you are just using "SERVER-XX" then you might need to put in "SERVER-XX.company.net". You also might have to log into the VPN if you are not on the local network.
If that doesn't work, IIS might not be running on the server, and it won't be able to find the server. You can always log into the server and try doing an IISRESET to restart it or start it.
Dave TaylorMCAD Solutions Engineer
Hagerman & Co.
Autodesk Certified Instructor - Platinum
Likes to this post are appreciated if the information I have shared is helpful to you and/or others...
**Did this resolve your issue? Please accept it
"As a Solution" so others may benefit from it.
