Vault client "Could not fine Data Management Services on SERVERNAME" logging into vault server.
tonythm
Message 1 of 14
tonythm
Dear All,
Anyone have a solution to this problem? Please help me.
I have entered the correct SERVERNAME as on the server machine but still the error.
Replies (13)
Message 2 of 14
Gabriel_Watson
If you are using Vault Gateway to connect to a Vault via cloud connection, the server field is an actual address: https://resources.imaginit.com/support-blog/autodesk-vault-gateway-returns-could-not-find-data-manag...
Or perhaps you just need to make sure you are connected to the same network, via VPN, or directly.
P.S.: other related articles for similar issues below
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Error-After-updati...
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/could-not-find-Dat...
Message 3 of 14
dave_taylor
Check to see if you can ping the server from the PC. You might also need to put in the FQDN (Fully Qualified Domain Name)...so if you are just using "SERVER-XX" then you might need to put in "SERVER-XX.company.net". You also might have to log into the VPN if you are not on the local network.
If that doesn't work, IIS might not be running on the server, and it won't be able to find the server. You can always log into the server and try doing an IISRESET to restart it or start it.
Dave Taylor
MCAD Solutions Engineer
Hagerman & Co.
Autodesk Certified Instructor - Platinum
*Likes to this post are appreciated if the information I have shared is helpful to you and/or others...
**Did this resolve your issue? Please accept it "As a Solution" so others may benefit from it.
Message 4 of 14
DarrenP
was it working before or has it never worked?
does anyone else in your office have the same issue?
DarrenP
Message 5 of 14
tonythm
@DarrenP
All other user machines get the same error.
This is our first time installing it.
Vault add in Inventor detects the vault server, but it just spins not logging in. On the vault basic app, the vault server is not detected. I don't know if I missed any installation step? Please help me.
Message 6 of 14
dave_taylor
Can you log into ADMS on the server? Can you get to the Tools>Administration page within the ADMS console?
Dave Taylor
Hagerman & Co.
Message 7 of 14
tonythm
@dave_taylor
I can login to ADMS console. and access Tools>Administration page.
Do you have any solution for my problem? Please help me 🙂
Message 8 of 14
dave_taylor
If you can get to Tools>Administration, then the webconfig is ok. Do you have a Vault client installed on the server? Can you login through it? Try installing the client on the server and see if you can login and try also "localhost" as the server name in the client on that server.
If you can login, it means there might be a firewall or something blocking the access...
Dave Taylor
Hagerman & Co.
Message 9 of 14
tonythm
@dave_taylor
I installed the vault client on the server and successfully logged in on the "localhost" server with no problem.
But when I log in vault client on the user machine on the same network, I get an error like I said above.
I have tried disable the firewall of both the server and the client but the error still.
Message 10 of 14
dave_taylor
Can you ping the server from the PC? Did you try using the Fully Qualified Domain name?
Dave Taylor
Hagerman & Co.
Message 11 of 14
tonythm
@dave_taylor
My PC is able to ping the server. The server shared the network drive for my PC.
Do I have to run IISRESET?
Message 12 of 14
jorgen.bjornes
try turning off firewall on server as a test.  if this works then configure the firewall.
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Is-the-Firewall-bl...
Message 13 of 14
tonythm
Thanks to everyone who suggested me solutions.
I sat down with the IT department, and I told them that something was preventing the client's connection to the server. And we have found that IT has used a 3rd party application to restrict external access for the purpose of data security installed on client computers. After disabling that feature, the Vault client was able to log in on the server.
Thank for all.
Message 14 of 14
dave_taylor
Glad you got it figured out. Everything you responded back to meant it was good on the server side, so I figured it was something stopping the connection. Cheers!
Dave Taylor
Hagerman & Co.
