Vault Basic to Pro Updating Category
controlsgirl
controlsgirl
Is there a faster way than the Vault GUI to categorize drawings and assemblies of existing content from a Vault Basic implementation?
Gabriel_Watson
As I understand, all Vault Basic files are basically in Work in Progress state. If you search for all WIP State files and include another criteria for date last modified, you will possibly see all of those in one search window and can assign categories to them.
ihayesjr
@controlsgirl
There isn't anything that will go through all of your files and place them into categories automatically.
However, if you have category rules created, you can select a group of files, select Change Category and in the Select a new category drop-down, select "Apply assessment rules".
Irvin Hayes Jr
Principal Product Manager
Autodesk, Inc.
Vault - Under the Hood Blog
controlsgirl
@Gabriel_WatsonThank you for your response! Do all of the files need to be in the same folder or can you multiselect files in different folders or files buried within subfolders? Or is there a way to make a file list by filtering certain strings in a filename? I am flying a little blind. Asking for a friend🙂
Gabriel_Watson
Multiselect across separate folders works because the query/search results lists all files regardless of where they are. Considering, of course, that you are searching all of Vault (or a top folder containing all the content).
I would recommend building a search with the Find tool, saving it, and then launching your search from the "Saved Searches" section of your Vault browser (left pane). This way you can easily maximize the results screen and click on More Results until you have them all. But you can also do it in sections, since there is no harm in changing a chunk at a time.
Your search criteria can be built in many ways, and I believe Vault is flexible enough to narrow this down as much as you need it. All you have to do is know what unique features/flags/properties those Vault Basic files have. Even if it is just their creation date being up to a certain date.
Other useful properties to work with as a filter for your situation may be "State", "Lifecycle Definition", "Date Version Created", "Date File Created", "Created By", "Original Create Date", "Folder Path", and/or "File Extension".
controlsgirl
Passing it along! I'll let ya know how it goes. Thanks.
