We have a vault backup set up using windows task scheduler and it was running great; however, we had to change to vault password and now the backup is throwing an error every time because the original password does not match up. Does anyone know where I go to update the password to the new password so that it will continue to run the backup. I was not the one who set up the backup and he no longer works here so any guess would help. Thanks.
I'm thinking it should be in the text file you use to set the backup. For me it's here where the asterisks are:-
D:\Program Files\Autodesk\ADMS Workgroup 2013\ADMS Console\Connectivity.ADMSConsole.exe" -Obackup -B"D:\VaultBackUp\Temp" -L"D:\VaultBackUp\VaultBackUpLog.txt" -VUadministrator -VP******** -S -DBSC
Hi ChristianAlanJamesBerg,
First you should open the windows task scheduler to see what script is it calling for the backup, then update the script as BLHDrafting's post.
