Vault 2026
Vault 2026
GosponZ
Vault 2026
GosponZ
We migrate from inv 2024 to 2026. We have Libraries and CC in basic vault. Question is if Vault 2026 support  Libraries and CC file? Thank you
BassEngineer
Yes, Vault Basic and Vault Pro 2026 supports libraries and CC.  As far as folder structure, migrating from Vault 2024 to Vault 2026 should be seamless.
The folder structure will not change as long as your .ipj file is mapped properly in 2024 and you use the same .ipj in 2026.
ihayesjr
Your libraries will need to be migrated to Vault 2026.
Inventor 2026 Help | Migrate custom libraries | Autodesk
Irvin Hayes Jr
Principal Product Manager
Autodesk, Inc.
Vault - Under the Hood Blog
CGBenner
@GosponZ
Hello, Did the information provided answer your question? If so, please use Accept Solution so that others may find this in the future. Thank you very much!
Chris Benner
GosponZ
YES THANKS
What should I do if I have to use both versions of Inventor 2024 and 2026 with Vault 2026? Do I need to install both versions of the CC libraries for each version of Inventor?
ihayesjr
Yes, you will need to install both versions of CC libraries.
Irvin Hayes Jr
Autodesk, Inc.
