Vault 2026 Local Help Issue
Maxim-CADman77
Advisor Advisor
Message 1 of 15
Maxim-CADman77
I wonder why corresponding page of help for Vault 2026 references local help for 2025? And where the local helps (Client and Thick Client all localisations) for 2026 can be downloaded from?
Please vote for Inventor-Idea Text Search within Option Names
Replies (14)
Message 2 of 15
gandhey
Hello @Maxim-CADman77 ,
This link is broken for now and will check with engineering team to fix this.
Also the help download itself doesn't seem available and will check further.
Yogeshwar
(Vault team)
Message 3 of 15
Maxim-CADman77
Please, let know when done.
Message 4 of 15
Maxim-CADman77
@gandhey Still no news for the topic?
Message 5 of 15
Maxim-CADman77
@gandhey , I wonder if there any perspectives the issue would be solved the month after it was reported?
Message 6 of 15
Maxim-CADman77
@gandhey , three months later the issue is not fixed..
Message 7 of 15
gandhey
Hi @Maxim-CADman77 ,
We are working on this and planning to fix this with next 2026 update.
Yogeshwar
(Vault team)
Message 8 of 15
Maxim-CADman77
@gandhey
There Update 2026.1 was published on 28 July but still the issue with local help is not solved...
Message 9 of 15
gandhey
Please check now - this help fix was pushed after some time after the release.
The zip file was already updated but the string showed 2025 - which now should be fixed as well.
regards,
Yogeshwar
(Vault team)
Message 10 of 15
Maxim-CADman77
@gandhey
I can confirm the issue is solved for ENU
but it is still actual for ?all? other languages (at least for those couple languages I've checked at random there are still links to 2025)
Message 11 of 15
gandhey
Please note - for english we have just fixed the broken link issue however the actual help-content is not updated as of now and we are working on this.
For localized help availability - this is work in progress and should get published in this week. (however in terms of help-content - note this will be same as english, as mentioned above)
regards,
Yogeshwar
(Vault team)
Message 12 of 15
gandhey
The localized help is available on in the above page. (we have fixed the broken link issue however the actual help-content is not updated as of now and we are working on this.)
regards,
Yogeshwar
(Vault team)
Message 13 of 15
Maxim-CADman77
@gandhey
Please notify here when true 2026 (English and/or localized) offline help be available for download.
Thank you in advance.
Message 14 of 15
ihayesjr
@Maxim-CADman77
May I ask why you use the offline client help?
Do your users not have internet access?
Irvin Hayes Jr
Principal Product Manager
Autodesk, Inc.
Vault - Under the Hood Blog
Message 15 of 15
Maxim-CADman77
Some people tend to study Software helps only when Internet is not available (in long business trips etc) 🙂
