Hola a todos, alguien me podría decir cual es la capacidad límite de almacenamiento que tiene vault basic 2023 y tambien en la versión professional.
Desde ya muchas gracias.
English Translation
Hello everyone, someone could tell me what is the storage limit capacity that vault basic 2023 has and also in the professional version.
From already thank you very much.
system requirements are here: https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/System-requirement...
if you mean something else provide more info
DarrenP
There are no storage limitations to either edition of Vault.
SQL Express is installed by default with a database limit of 10 gigs. However, this limitation is removed if you install SQL Standard or higher.
thanks for your answer, but i have a question. Is possible to install and work vault basic 2023 in SQL standard or higher without problems?
Yes, all Vault editions work with SQL Express, Standard, and Enterprise editions.
You can pre-install SQL server before installing Vault or you can upgrade the SQL Express edition to a high edition after installing Vault.
Vault 2023 Help | SQL Administration Tasks for Autodesk Vault | Autodesk
