Vault 2022 Forge Viewer Measure - doesn't always allow to measure
steveh5
Advisor Advisor
Message 1 of 17
steveh5
Gang...
The new viewer technology in Vault is awesome.
But, on some files, I don't have ability to measure the models.
The idw's seem to be fine.
I Updated the model dwf via the Thick Client (Update) but still won't measure.
Any idea what determines if I can measure a model or not?
Best,
Steve H.
Steve Hilvers
Inventor Certified User / Vault Professional Influencer
Replies (16)
Message 2 of 17
CGBenner
@steveh5
Hi Steve... hope you're doing well!
Is this consistent with all models, or are there only certain ones that you cannot measure?
Chris Benner
Message 3 of 17
steveh5
Hello Chris...
Yes, fine here. Thx. Hope same is up there.
Only certain models. Some act as they should.
They all view fine, just can't measure on Thick and Thin clients on certain files.
It's isolated to Thick Client and Thin Client browser (Think Forge Viewer is local on these two when viewing).
I tested on mobile app and same file I can measure. But, I think the Forge viewer runs externally on the app.
Best,
Steve H.
Steve Hilvers
Message 4 of 17
CGBenner
@steveh5
Do you have an easy model that you could share?  Simple part maybe?  I'd like to see if I get the same results.
Chris Benner
Message 5 of 17
steveh5
Chris...I will send a private message.
Steve Hilvers
Message 6 of 17
CGBenner
@steveh5
Thanks, got the file.  I was able to measure with this in thick client, both in the preview window and with using View to pop out to a larger window.  I don't have thin client set up so I'm not able to test there.
Might be time to bring in @ihayesjr to have a look?
Chris Benner
Message 7 of 17
ihayesjr
@steveh5
What build of the Vault client are you on?
Irvin Hayes Jr
Principal Product Manager
Vault - Under the Hood Blog
Message 8 of 17
steveh5
@CGBenner...that's good to hear. It's isolated to our environment
 @ihayesjr
2022.2.1 (Build 27.2.67.0)
Best,
SteveH
Steve Hilvers
Message 9 of 17
ihayesjr
Hi @steveh5
I was able to verify your issue with Chris' help.
I have created an internal defect for it. PDM-35859
Please log a product support case so that we have the issue tracked properly.
Irvin Hayes Jr
Message 10 of 17
steveh5
Thanks gentlemen....
Case ID: 18712152
Best,
Steve H.
Steve Hilvers
Message 11 of 17
johannes.bauer
Autodesk Support
Autodesk Support
2022.3 was released yesterday where this is fixed.
HTH
-Johannes
Customer Technical Success
Message 12 of 17
steveh5
Thank you Johannes...will try it out this weekend.
Best
Steve Hilvers
Message 13 of 17
steveh5
Looks like a Vault and Inventor patch came out yesterday.
Assuming this is a Vault Client update that fixes it?
Steve Hilvers
Message 14 of 17
steveh5
Assuming the Server patch has not been released yet? That would fix the Thin client?
Steve Hilvers
Message 15 of 17
johannes.bauer
Autodesk Support
Autodesk Support
Server and Client Vault Patch are available.
The Server patch is for the Thin Client Viewing and do not forget to clear the cache in the browser,so the new data gets loaded.
HTH
-Johannes
Message 16 of 17
steveh5
Thanks Gentlemen...
Appears to be fixed.
Best,
Steve Hilvers
Message 17 of 17
steveh5
Sorry Gentlemen...
Did a little more testing and not sure it's completely fixed...I have to turn on a setting and can't measure holes.
https://autode.sk/3M7oB1a
Video demonstrates what I am seeing.
Best,
Steve Hilvers
