Vault 2020 - users get dwfx creation error upon check in of .idw files
TYoung_Combi
Message 1 of 16
TYoung_Combi
After upgrading to 2020 a couple of weeks ago, I am having many of my users reporting the error shown below when checking in .idw files to the vault:
The work around has been me, as admin, deleting the existing .dwfx file and then the users can check in without receiving the error.
Is there any way to stop the error from occurring and allowing the users to overwrite the .dwfx file with no issues?
Replies (15)
Message 2 of 16
cbenner
Message 4 of 16
upchurt
Hi @TYoung_Combi  thanks for reaching out vis the forums.
Which edition of Vault are you using where you are seeing these errors? Is it Basic/Workgroup/Professional?
Can you check the permissions on the DWF files in Vault to see if they may have accidentally had some permissions applied to them that would prevent users from overwriting them? Right click the files and go to their details then security tab to see what permissions might be applied.
Also please check the visualization attachment options in Vault as this error can occur if files are not having their attachments removed after certain actions. In the Vault client go to Tools -> administration -> vault settings then Visualization tab and 'define visualization attachment options.' and post what settings you are using here.
-Trent
Trent Upchurch
Message 5 of 16
TYoung_Combi
@cbenner wrote:
@TYoung_Combi
Here is a question... are you using Job Processor to generate the .dwfx files?
No; I have each user set to create a dwfx upon check-in
Message 6 of 16
TYoung_Combi
-Trent
We are using Vault Professional 2020.
Here is a screenshot of our 'Visualization Attachment Options":image.png
Message 7 of 16
upchurt
Thanks @TYoung_Combi that looks like the default options so I don't think the attachment options would cause these errors.
Did the permissions for the DWFx files show that any security was being applied to them? Are you still seeing these errors and do they occur every time the same drawing is checked in?
Trent Upchurch
Message 8 of 16
upchurt
@TYoung_Combi I wanted to follow up and see if you were still getting this error or if deleting the associated DWFx files resolved it.
Let me know if you are still seeing this problem.
-Trent
Trent Upchurch
Message 9 of 16
TYoung_Combi
@upchurt If I delete the associated DWFX files, users can then check in with no issue. That has been our workaround. Just not sure what is the root cause of the issue. I appreciate the help!
Message 10 of 16
upchurt
@TYoung_Combi  thanks for the follow up. Can you send me a screenshot of the effective access for these files and the users that are checking in the CAD files? I suspect that the files may have some permissions applied to them that is preventing the CAD users from checking them in.
Does the problem happen on every file or only some? Is there a particular workflow that causes it and can you send me a screencast of it?
-Trent
Trent Upchurch
Message 11 of 16
upchurt
@TYoung_Combi I wanted to follow up on this post and see if you were still seeing the problem or had a chance to check the permissions on these files.
Let me know if you still need help.
-Trent
Trent Upchurch
Message 12 of 16
TYoung_Combi
I forgot to come back and post the permissions. My apologies; the C-19 preparations have been paramount the past few days.
I may not be looking for what you need to see, but here are details for one of the .dwf files:
Is this what you are asking for?
Message 13 of 16
upchurt
@TYoung_Combi that is close, go to the effective access tab there and add the user that is trying to check in/update the DWF file to see if there is any other permissions being applied.
-Trent
Trent Upchurch
Message 14 of 16
upchurt
@TYoung_Combi did you have a chance to test out the effective access for these DWF files?
I have a feeling that working through this forum post is not going to solve this issue. If you still need help please create a support case and I will follow up with you and we can take a look at the issue together.
-Trent
Trent Upchurch
Message 15 of 16
upchurt
For anyone finding this thread and seeing the same issue we found that this error was causing by the Vault visualization attachment management settings being switched off. This caused orphaned visualization files that could not be overwritten except after they were deleted.
We were able to workaround it by sending the DWF creation jobs to the Vault Job Processor which ran using an Administrator account which in most cases could overwrite the DWF and if not would collect the errors/paths for the DWFs files to be deleted/created new.
Trent Upchurch
Message 16 of 16
This happens when you rename files... Vault doesn't update dwxf files
