Vault 2020 "Stock Number" from Inventor files only shows up for Content Center created parts.
Sfusinski
Message 1 of 12
Sfusinski
Heyas!
I went through and assigned iProperties to all of my details for a model. When I checked them into Vault, I noticed that the field for "Stock Number" is blank for almost every part, except for the Content Center stuff (pipes etc).
Does anyone know what would cause this to be the case? Every single thing on that list has information in the right (stock number) field, and yet only the pipes show up.
Replies (11)
Message 2 of 12
dave_taylor
Are your mappings set to be either bi-directional or from either Vault or from the File (depending on where you are writing them) for Stock Number in the Vault? Are there multiple mappings which could cause it to be blanked out?
For troubleshooting, you can also try updating the stock number property in Vault and do a Synchronize Properties to see if it holds...
Dave Taylor
MCAD Solutions Engineer
Hagerman & Co.
Autodesk Certified Instructor - Platinum
*Likes to this post are appreciated if the information I have shared is helpful to you and/or others...
**Did this resolve your issue? Please accept it "As a Solution" so others may benefit from it.
Message 3 of 12
Sfusinski
Thanks for the response!
Where can I find the settings to check if it is bi-directional?
As of now, the properties that don't show up are checked in via Inventor.
I figured it would be under Admin/Property Definitions, but it doesn't seem to be the case.
Message 4 of 12
Gabriel_Watson
Tools > Admin > Vault Settings > Behaviors > Properties > select an User-Defined property (person icon) then either: 1) pick mapping on the lower section, or 2) click Edit first then Mapping to modify.
Message 5 of 12
Sfusinski
Thank you for leading me there, but unfortunately mine already say yes to both mapping directions.
Is there anything you can think of that would cause parts created via Content Center to show their stock number values in Vault, while the parts created via "new" do not?
Message 6 of 12
dave_taylor
Have you tried a Synchronize Properties on a file that you know has Stock Number filled out and not showing? If it still doesn't show, you might need a property re-index in the Vault. Those properties show in the Vault client from the vault index of the properties.
Dave Taylor
Hagerman & Co.
Message 7 of 12
Sfusinski
I have done a workplace sync, and nothing has changed. I am not sure how to go about just syncing the properties themselves.
I deleted the local files I had and did a "get" to pull them from vault to see if anything was conflicting. The parts themselves still all have the data entered while still now showing so in Vault.
Message 8 of 12
dave_taylor
Not a workspace sync. That is doing nothing other than checking the files you have downloaded locally in your workspace on your PC compared to Vault. You need to do a Synchronize Properties on the file to check it within the Vault...select the file, go to Actions>Synchronize Properties
Dave Taylor
Hagerman & Co.
Message 9 of 12
Sfusinski
Thank you, but no change in displaying them.
Message 10 of 12
ihayesjr
@Sfusinski
Check the category that the parts are in have the Stock Number property assigned to it.
Irvin Hayes Jr
Principal Product Manager
Vault - Under the Hood Blog
Message 11 of 12
Sfusinski
Message 12 of 12
Sfusinski
So, changing the category to a different one had the part numbers pop up, I am going to tinker with them now.
Thank you so much!
