Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Vault 2018. Poor PDF quality.
6 REPLIES 6
FedotovAnton
869 Views, 6 Replies
Job Server generates very poor quality pdfs, but only for big drawings (attached screenshot). We already tried set all the DPIs - there is no difference.
Is it a bug?
Anton
6 REPLIES 6
How is the quality when you generate the PDF from the native application (AutoCAD or Inventor)?
Senthil Kumar
Development Manager,
Be sure to check out the Vault Help!
Perfect quality from Inventor (we're using only Inventor).
Our coders say that this the issue arises because Inventor does not have time to render all views before publishing.
Thanks for the confirmation. Please raise a ticket with Product Support along with the required dataset. We can get that investigated. Thanks.
Senthil Kumar
in reply to: Senthil_Kumar
The issue was solved by un-ticking the option "Enable background updates" in Inventor Application Options>Drawing>Capacity\Performance.
I am seeing this issue here as well. I am experimenting with JP to print PDFs. The quality will be good and then all of a sudden it goes to pieces.
I have turned off Background updates on the JobServer. We will see if our PDFs become consitent.
dariuszm
Is uncheck box help You?
Technology Administrators
