Hi We are upgrading from Vault 2014 to Vault 2018. One of the new features is the quick checkout button in addition to the get/checkout button.
When the user is not having permission to access a certain folder he gets a permission error while checking out using get wizard which is expected behavior.
Now the issue is, when he does a quick checkout on an object to which he doesn't have permission nothing happens. The object doesn't get checked out but he also doesn't get any error/prompt which is strange.
Thanks and Regards,
Praveen
Solved by Senthil_Kumar. Go to Solution.
Praveen,
The Quick Check out command is designed that way. So it is working As Designed.
Thanks for the Prompt Reply Senthil. So you mean to say using a quick checkout the user will no get any kind of feedback from the system if he doesn't have permission to checkout the object?
Correct Praveen.
