Not sure what can be done about this. But when launching Vault Client fully hotfixed as of today at 2017, the UI scales OK on 4K.
But as soon as you invoke a Get, and I imagine many other dialog boxes, the Client completely disconnects from UI Scaling and becomes unreadable.
After launch at 4K, everything looks good:
Invoking the Get:
It stays that small until a client re-open is performed:
Solved by ihayesjr. Go to Solution.
Hi Neil,
Close Vault, right click on the desktop icon and go to the Compatibility tab. Check the box next to Disable display scaling on high DPI settings.
What does that do once you launch it again?
Thanks Irvin that actually made a massive difference, the client no longer shrinks and is usable. Many of the UI elements are still out of proportion and look messy at 4K but it's a lot better with that option checked.
