Value cannot be null. Parameter name: path1
alex_hiis6PJP6
Message 1 of 14
alex_hiis6PJP6
Hi
Migrated to Inventor 2025 and have been getting this message when opening Inventor files from Vault.
Tried this solution but it didn't work:
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Error-Value-cannot...
Replies (13)
Message 2 of 14
CGBenner
@alex_hiis6PJP6
Hello and welcome.  Can you tell us more about what Vault you are working on?  Is it also 2025, and is it Basic or Professional?
Chris Benner
Message 3 of 14
alex_hiis6PJP6
Hi @CGBenner. We are using Vault Professional 2025.
Message 4 of 14
CGBenner
@gandhey Do you have any thoughts on this topic?
Chris Benner
Message 5 of 14
alvin
I have also just started getting this error after applying the 2025.1 update, both server and client.
Message 6 of 14
alvin
@alex_hiis6PJP6
Alex, I have just had our support guy connect to my machine to look at this error and he has managed to sort it my changing the Opening behaviour within Vault, from Last State to Default.
I have attached a screen shot of where he made the change within the client.
Not sure if this will address your issue but it is at least worth a try.
Message 7 of 14
CGBenner
@alex_hiis6PJP6 Did the information provided answer your question? If so, please use Accept Solution so that others may find this in the future. Thank you very much!
Chris Benner
Message 8 of 14
alex_hiis6PJP6
Thank you @alvin. That option did stop the error from popping up.
Message 9 of 14
mats.jakobssonMKR5Q
Have the same problem after uppdates. Run Inventor as "administrator". Then shut down Inventor and then start Inventor as normal.
Most problem fixes when you run Inventor once as "administrator" its acces problem to write in to the windows registry....
Message 10 of 14
kevinhtucker
Nice one! That definitely worked without having to change any settings or rename the folders in AppData\Roaming as per Autodesk's suggestion.
Message 11 of 14
Marco_cuterL89WC
Observer
Observer
Thanks alot for your help. It seems incredible but it was the one.
Message 12 of 14
Ryan_Monahan-Sundberg
Chiming in on Vault 2026, this fix is still important. Thumbs up. While users CAN get around it by opening from Inventor "through" the Vault, this fix is required to resolve the null pointer error when opening from Vault client directly.  Tools / Options ->  Open File Behavior Settings - click the Settings button next to it. Set ALL to default.
Message 13 of 14
andrewf
Thank you for posting this! Worked like a charm
Message 14 of 14
Nathan.GrahamJ8CRS
Thanks Ryan, your solution works best for users who cannot "Run as Administrator"
