Unable to control font color since dark mode was introduced
JonathanKruger
Message 1 of 9
JonathanKruger
Vault has now got a dark mode which is great as it looks more inline with how AutoCAD and Inventor Dark mode look but there is a little issue with color choice.
When you have a file checked out the default color is Bold Dark Blue, and Dark Blue on Dark Grey on some screens makes it difficult to read easily, I was wanting to change the "CheckedOutByUser" color to Gold as this would probably look easier on the eyes. There is an old post which shows describes how this can be done.
Now if I edit the config file the only mode that honors these "Color" settings is "Classic". Dark and Light "Themes" seem to ignore it, is there another file I need to edit to get the font colors to change?
The really strange thing to me is that Vault follows all the other options like "BoltText" and "Strikeout", it is just the Color value that get ignored.
If this solves your issue please mark this posting with the "ACCEPT SOLUTION".
If you like something that was said or if it was helpful, Likes are appreciated. Thanks!
Replies (8)
Message 2 of 9
Senthil_Kumar
@JonathanKruger Thanks for posting this issue. The Dev team confirms the issue and looking into fixing this in the future updates. Sorry for the inconvenience.
Senthil Kumar
Development Manager,
Autodesk, Inc.
Be sure to check out the Vault Help!
Message 3 of 9
jpeters9XH3R
having this issue as well, has this been addressed at all? currently using Vault basic 2023
Message 4 of 9
CGBenner
@Senthil_Kumar is there any update on this?
Chris Benner
Message 5 of 9
Senthil_Kumar
@CGBenner  I hope this Article helps.
Senthil Kumar
Autodesk, Inc.
Message 6 of 9
jpeters9XH3R
Hi I don't seem to be able to follow the links through to the knowledge document to try fixing the issues in vault basic 2023
Message 7 of 9
Senthil_Kumar
Sorry. The link seems to be broken. Here is the Link to the right article.
Senthil Kumar
Autodesk, Inc.
Message 8 of 9
jpeters9XH3R
That's fixed it thank you.
Message 9 of 9
marina.collet
Hi Senthil,
This color setting for checked-out files are not consistent throughout the Vault (different colors in different Windows).
Is there a way to have the same colors everywhere?
In my sample image, you can see that:
- I have a set the color to golden in my main grids (changed the value in the Connectivity.VaultPro.exe.config file)
- I have a dark blue color in the "Change State" window (hardly readable) same in "Change revision" window.
- I have a light blue color in the "Get" window
- I have a bright red color in the "Change category" window
