Searching for quotation marks
Electrik
Electrik
I've become aware that we have some files with quotation marks in the Part Number field (used for inches). How can I search for these? With the quote marks used to typically identify the search phrase, everything I've tried has returned everything - all files.
Inventor Professional 2021
Vault Professional 2021
ihayesjr
@Electrik
You will not be able to use Search to find it but you can use a column filter.
In the main grid, add the Part Number column.
Hover over the column until you see the filter icon in the upper right corner.
Click it, and in the Values tab, you can enter a quote. This should show you which file has a quote in the part number value.
You can also use the Filter tab in the same box and it will filter the entire grid to files that have a quote in the part number field.
Irvin Hayes Jr
Principal Product Manager
Autodesk, Inc.
Vault - Under the Hood Blog
Electrik
That's great. Being able to set create the filter allow me to quickly check folders, one at a time. But there's not a way to get the Vault as a whole?
ihayesjr
Unfortunately, there isn't. Can you create an Idea Post so we can review it for a future enhancement?
Irvin Hayes Jr
Autodesk, Inc.
Electrik
ok, thank you very much!
