Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Scroll Bar in the Copy Design Numbering Tab not working
6 REPLIES 6
347 Views, 6 Replies
In the Copy Design Interface for Vault Pro 2017 the scroll bar on the numbering tab does not pan over and back through the listed columns.  You have to expand the panel to get to the columns on the right of the list.
6 REPLIES 6
Senthil_Kumar
Senthil_Kumar
Hi Jon,
Thanks for reporting this problem. I have forwarded this to development team. We will keep you informed once we have the fix. Thanks again.
Senthil Kumar
Development Manager,
Autodesk, Inc.
Be sure to check out the Vault Help!
Hi Jon,
Senthil Kumar
Autodesk, Inc.
Ryan8749548
Ryan8749548
It is disappointing that this feature is still not available in 2024.
edit;
Actually it seem to be working on numbering pane, however I do not understand why it is not available in the main browse pane!?
edit;
johannes.bauer
johannes.bauer
Autodesk Support
Autodesk Support
@Ryan8749548 Can you try to make it smaller and see if the scrollbar appears? it does in my copy design in 2025
HTH
-Johannes
Customer Technical Success
HTH
-Johannes
Ryan8749548
Ryan8749548
Hi Johannes,
Thanks for your quick response
(and sorry for hijacking this thread out of frustration)
Yes it does show the scroll bar as you have shown, but only when the width of browse pane is unusably short!
it is impossible to see anything meaningful and it really should work even when the width is at maximum to show every column in full length.
Hi Johannes,
Senthil_Kumar
Senthil_Kumar
@Ryan8749548 Can you please show me when you need the scroll bar in the main window? A video or an image showing the need will be super useful. Thanks a lot.
Senthil Kumar
Autodesk, Inc.
Senthil Kumar
Autodesk, Inc.
Ryan8749548
Ryan8749548
Please notice the difference on the scroll bar between the two pictures.
I hope you can see that it is just not practical to have it like this.
I suspect it is an outdated legacy code for resolution less than 800x600
I am currently on 3440x1440 however the problem is the same with 1920x1080 (see attached) 
