Scheduling server tasks
gordow
gordow
I would like to change the scheduled time for the vault server tasks.  These are the tasks that show up when "View Server Tasks..." is selected in the ADMS Console (see attached screen grab).  We are running ADMS Console 2012 on a server running Windows Server 2008 R2 Enterprise.
Thanks for any help.
gordow
paul.gunn
I'm sorry there is no general way to edit the scheduled tasks. Specific tasks have different mechanisms for scheduling - e.g. replication tasks can have time scheduled from the 'replication schedule' dialog. Is there some specific task that you are looking to adjust scheduling for?
Paul
gordow
Hi Paul,
Thank you for your reply.  The tasks I am considering moving are the Search Index Optimization and File Store Cleanup at 1 AM and 2 AM, respectively.  We have folks that work into the night and others that start early in the morning, frequently even on weekends.  I would like to start a scheduled backup to run after these tasks are complete, but it takes about 5-1/2 hours to backup and validate our vault.  The vault would be locked and inaccessible to these early-birds and nightowls while the backup is running.
I also want to find out, if these tasks are configurable, if other tasks can be added to do something like schedule a periodic Purge at an early hour.
Thanks again.
gordow
paul.gunn
The execution time for those settings can be configured in web.config on the server. While this paper was targetted at vault 2009, the information on changing these settings is still accurate: http://images.autodesk.com/adsk/files/vault_background_processes_whitepaper.pdf
Purge can be run from the ADMS console command line, so could be scheduled via windows task scheduler. Note that purge can take some time on a big vault so this is not something I'd necessarily recommend running nightly. Information on adms console command lines:
http://help.autodesk.com/view/VAULT/Help/ENU/?guid=GUID-7FD9DAD8-0104-46FA-BCE7-11259FAB4235
Hope this helps,
Paul
gordow
Paul,
I have read through the information you attached and it appears the solution is there.  I will have to try it out in the days to come.  Thanks again.
gordow
