Running Vault basic 2018 on 1 computer, 1 user
MikeKovacik4928
Advisor Advisor
Message 1 of 17
MikeKovacik4928
Hi all
I am wanting to test vault to see how it works.
I would like to run it side by side with drawings that will not be in vault.
Basically I will  create a copy of the non vault drawing (maybe with an appendix
to differentiate it) and check it into vault.
This will all be on 1 computer,maybe using a different directory for the vault testing,
with one user (ie myself)
I have installed Vault basic 2018, but that is as far as I have got.
I can't get any further. It keeps coming up with message
"Vault Basic could not find the Data Management Services on localhost"
What does this mean? How do I get my first drawings logged into vault
Michael Kovacik
2d & 3d Autocad and Inventor designer/draughtsman
Draughting/Designing (Manufacturing) (31 yrs)
-Drawing Board (3 yrs)
--Cad (28 yrs)
---Cadkey (4 yrs)
---AutoCAD 2d & 3d (16 yrs)
---Inventor (4 yrs)
---Autocad and Inventor Simultaneously (4 years)
---(and recently Autocad/Inventor Customisation)
Higher Diploma Mech Eng
Member SAIMechE
Technician Member ECSA
Collaborator (Rank 9) on Autocad & Inventor Forum
Autodesk Product Design Suite Ultimate 2018
Autocad 2018, Inventor Pro 2018
(personal licensed copy)
Johannesburg, South Africa
(Impossible only means you haven't
found the solution yet)
Replies (16)
Message 2 of 17
rtowne72
Have you installed Vault Server Basic?
Rob Towne
Sr. Engineer/CAD Manager | A.L.P.
Inventor/Vault Professional/AutoCAD
Message 3 of 17
MikeKovacik4928
Rob
I have installed the vault basic that comes free with the software.
I will give you details tonight when I am at home.
I am doing this at home and I do not have it here at work.
Mike
Message 4 of 17
Rob67ert
I guess you did not install the Vault Basic server.
Depending on the type of product, run set up and then go to tools. Or download the Vault server install files.
Remember to have the server en client at the same version and update.
Robert
If you find this reply helpful ? It would be nice if you use the Accept as Solution or Kudos button below.
Message 5 of 17
MikeKovacik4928
Rob
I have installed Autodesk Vault Basic from the Autodesk Data Management (see attached jpeg)
Is this the Vault Server Basic you are talking about.
If so I have installed it and I still get error messages I have indicated earlier
If not, what is it, and where do I find it?
Mike
Message 6 of 17
rtowne72
You will need to get Vault Basic Server as well for the Vault system to work.  See this link to show where to obtain Vault Server within your Autodesk Account :https://forums.autodesk.com/t5/vault-forum/how-to-download-vault-basic/td-p/7475185
The Client connects to Vault Server (where the files and data is stored) and without the server you will get the errors you are seeing.  Here is a web link giving the overview of the Architecture and how to get started : https://knowledge.autodesk.com/support/vault-products/getting-started/caas/CloudHelp/cloudhelp/2018/...
Please take a look at these links and let me know if you need more help.
Rob Towne
Message 7 of 17
Jason.Courtemanche
Hi @MikeKovacik4928,
I'm just checking in to see if you need more help with this. Did the suggestion that other provided work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Jason
Message 8 of 17
MikeKovacik4928
Thanks All
I haven't managed to get this to work yet.
See attached screenshots for what I attempted to do,
in the end still couldn't log in, as administrator
because I didn't have a password and didn't know how to do it.
It seems very complicated.
For now I am giving up.
I will give itanother try some other time.
Inventor Queries_095_Test Run Parallel Vault Basic-016.jpgInventor Queries_095_Test Run Parallel Vault Basic-013.jpg
Mike
Message 9 of 17
Jason.Courtemanche
Thank you for the update, I am sorry to hear your still having issue getting Vault Server working. If you are interested please send me a private message with our phone number and we can do a screen share Monday 22th at 1:00 pm EST and look at this further.
Jason
Message 10 of 17
MikeKovacik4928
Thanks Jason
I would be interested, that would be 6 pm here and I would be at home.
How would that work? What phone number do you need? My land line here at home?
I am not on fibre but on an adsl telephone line.
The screen shots I posted were from my laptop where I tried with Inventor 2017,
and on my desktop with Inventor 2018
I have 2017 & 2018 loaded on both my laptop and desktop at home.
Which one would we link up to? laptop or desktop?
Sorry for all these questions, I am pretty new to this sort of thing
Regards
Mike
@Jason.Courtemanche - edited post - removed customer contact information
Message 11 of 17
Jason.Courtemanche
It was a please speaking with you. I am glad we were able to get the Vault Server to run. The software was crashing because the SQL Server was not running. Once we get SQL Service to run we were able to open the ADMS Console and make a new Vault.
Vault logs:
Error: The connection to the database has been broken. Reattempting operation.
Exception: A network-related or instance-specific error occurred while establishing a connection to SQL Server. The server was not found or was not accessible. Verify that the instance name is correct and that SQL Server is configured to allow remote connections. (provider: SQL Network Interfaces, error: 26 - Error Locating Server/Instance Specified)
Stacktrace: at Connectivity.Core.Database.TransactionContext.OnSqlException(SqlException e)
at Connectivity.Core.Database.TransactionContext..ctor(TransactionDatabase database, DatabaseUser databaseUser, Boolean transact)
at Connectivity.Core.Database.TransactionBase.SetupTransactionContext(TransactionReqs transactionReqs, TransactionDatabase database, Nullable`1 databaseUser)
at Connectivity.Core.DataAccess.LegacySystems.DetermineKVMName()
at Connectivity.Core.DataAccess.LegacySystems.LegacyTransaction._TransactionDatabase..ctor()
at Connectivity.Core.DataAccess.LegacySystems.LegacyTransaction..ctor(TransactionReqs transactionReqs)
at Connectivity.Core.DataAccess.SiteCompatibility.GetSiteCompatibilityWithKnowledgeMaster()
at System.Runtime.Remoting.Messaging.Message.Dispatch(Object target)
at System.Runtime.Remoting.Messaging.StackBuilderSink.SyncProcessMessage(IMessage msg)
Jason
Message 12 of 17
MikeKovacik4928
Thanks Jason
Appreciate the call.
Will try out and report back
I can't figure out how to delete the message with my phone numbers on, can you do it for me
Mike
Message 13 of 17
Jason.Courtemanche
@MikeKovacik4928,
Sounds good, just deleted your contact information and left the rest of the post.
Jason
Message 14 of 17
MikeKovacik4928
Jason
Can't get past this step.
11) In the Vault Log in dialogue box, select the newly created Vault database
See attached PDF, the vault log in box does not show the newly creaed Vault database
Mike
Message 15 of 17
Jason.Courtemanche
Thank you for the update. I understand you are on step 11 - setting up a Single Inventor Vault Project File
What is the error you get when you Select "Vault", then "OK"?
Leaving the hostname as localhost is fine as the Vault Server is installed on the computer.
Make sure you can still log into the Vault Server using the Vault Client, this will help narrow down that the issue only happens with the Inventor Vault add-in.
Jason
Message 16 of 17
MikeKovacik4928
Jason
Will reply from home tonight as this is only a home experiment
I am at work at the moment.( we are EST + 8 here not +6 like I told you before.)
Mike
Message 17 of 17
MikeKovacik4928
Jason
Thanks for the phone call, and link up on team viewer, and for getting my vault working at home
on my laptop
Mike
