Message 1 of 23
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am having a trouble restoring 2014 Vault backup.
We are upgrading 2014 Vault to 2016 Version. Below are the steps have been done so far:
- I've created a backup from 2014 vault and copied it to the new server where ADMS console to be installed.
- We also setup a new MS SQL server on a different server (vrdw-150-99), therefore MS SQL is located on one server and ADMS 2016 (to be installed) is located on another server.
- I've created a shared network folder on MS SQL server called ADSKVault_transition
- I've installed ADMS console by expanding the triangle and entering the following:
- remote database: vrdw-150-99
- required network share: \\vrdw-150-99\adskvault_transition
- ADMS Vault Server was installed
- then I tried to restore from the backup entered the following:
- backup location: f:\VaultBackup_2020_03_08_8_00_28_PM
- database data location: default
- restore location: f:\Vault_Restore_Location\file_store
After that I received the following error: "Illegal pathname or filename '\\vrdw-150-099\adskvault_transition''
What did I do wrong? Please help.
