Renaming -"An existing connection was forcibly closed by the remote host."
- Mute
- Permalink
- Report
I am attempting to rename a vault, as well as the main project folder. I was able to rename the vault by detaching and reattaching, however when I try to rename the project folder I get the above error.
At first I was trying to rename from a client machine, after about 2 hours of a dialog box reading "renaming folder", the error showed up.
I then installed the Vault Pro 2019 client on the same physical computer that is running Vault Pro server 2019, thinking it might have been a network packet issue. Nope, after about 2 -3 hours of Vault trying to rename the folder, I get the same error.
The project folder I am trying to rename consists of about 260,000 CAD files, a good majority of them being versions files. I did do a purge of the versions files before attempting the folder renaming.
Any solutions to this issue? Is my vault too large (260,000 files, 280 GB) to where the renaming command is timing out?
