Could you please check the DPI setting? There is a known issue using 120
DPI and we are looking into it.
If this is indeed the issue, use 96 DPI instead.
Carol
"npet" wrote in message news:5940758@discussion.autodesk.com...
I have an issue with Embedded DWF Viewer ActiveX. Viewer in not docking to
the viewer tab container.
I attach a picture.
I get the same problem in 4 pcs.
The pcs that I installed PS are HP workstations with Windows XP Pro.
Thank you!
