Property mapping without data management console server
Hi all,
My requirement is mapping a autocad drawing with block attributes with vault properties.
I need a solution to map user defined properties to autocad block attributes.
I can gone through searches and found that without data management server, we can't map block attributes.
Is it so or is there any solution to map without adms console?
Thanking you,
Arun.
JamesMcMullen
Hi Arun,
I am a bit confused.  How did you plan on mapping the Vault properties without the ADMS?  The properties inside Vault are stored within the database which requires an ADMS somewhere in your environment.   Are you running into a problem where you cannot add the title block to the ADMS because of a corporate requirement?  I am just trying to understand what is needed.
Jim
James McMullen
Principal SQA Eng.
cbenner
@Anonymous
I have to agree with @JamesMcMullen, this is an odd question.  Are you saying that there is NO ADMS, or just that you do not have access to it?  Is there an Admin that can add the Attributes for you in the server?
