Project Folder Mapping - Project Root
w.poortinga
w.poortinga
I'm having Vault issues which are, I think, related to the following: I am unable to set the right folder path to Project Root:
I can only select sub-folder of the root. Is there a way to do this right?
Thanks in advance!
Richard.Rankin
Autodesk Support
Autodesk Support
Hi @w.poortinga,
In your active Inventor Project file, you need to define a subfolder to your Workspace.
It might help if you follow the instructions in this best practice....
Using Autodesk Vault with a Single Inventor Project
If you find my response solves your question, please click the "Accept Solution" below the response
Richard Rankin
Vault Support Specialist
Global Product Support
Autodesk, Inc.
w.poortinga
Thanks. That worked. I tried something like this before because it seemed logical (judging from the error text) however I still didn't get it working then. I must have done something different this time, it works now 🙂
Moved:
Richard.Rankin
Autodesk Support
Autodesk Support
Hi, I've come across the same issue but when I attempt to change the workspace path it doesn't give me the option and "Edit" is greyed out. Any ideas about this?
Thanks in advance.
danPXEFD
You need to click the little pencil on the right.
